are references a good way of data transfer between parallel loops at different rates?
To transfer Numeric values back and forth between two parallel loops. I am currently using references. It works fine. What would be the best way considering different rates of while loops. Thanks!
V
I may not be perfect, but I'm all I got!
Message 1 of 14
(3,959 Views)
Functional global???
Message 2 of 14
(3,952 Views)
I usually use queues or an Action Engine.  Using references ties things to indicators and the UI thread which may produce a performance reduction.
Lynn
Message 3 of 14
(3,951 Views)
THanks for the quick response. A simple example of functional global and action engine would be helpful. Like really simple example to get the concept right. Any directions on that?
V
Message 4 of 14
(3,941 Views)
Correct and correct UNLESS you are talking about a DVR = Data Value Reference.
See here for my Nugget of Action Engines.
Ben
Message 5 of 14
(3,940 Views)
They are the same thing. Go to Google and type in "labview functional global" and the first hit should provide an explanation.
Message 6 of 14
(3,933 Views)
@ Ben, I have tried understanding your nugget a few times. It kinda jumps in to the concept directly and I find it hard to correlate it to when I actually have to use it. But, I will give it another shot. Reading n times always helps.
THanks all!
Message 7 of 14
(3,924 Views)
Are there any examples out there that have action engines implemented? Theory only does so much to my understanding. 😞
Message 8 of 14
(3,922 Views)
There are examples included with that nugget.
It also looks like I added an Actin Engine to the Tetris Game (post 26?) in this thread.
Ben
Message 9 of 14
(3,916 Views)
I attached the most basic example I could think of.
Message 10 of 14
(3,911 Views)
