are the VISA functions threadsafe?
I developed an application using 4 different threads for serial communication with 4 virtual COM ports (the same reentrant VI is called in every thread).
I discovered that if my applications hangs for some seconds executing one of the VISA functions (before returning with timeout error) I have some problems also in the other threads.
I wasn't able to fiund out if the VISA functions are threadsafe or not.
Could someone give me an answer?
Thanks in advance
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,028 Views)
You should read this thread.
(3,014 Views)
