area of a contour plot
I wish to get the area of a contour plot  or its projection on a relevant plane in Cwgraph3D.  i dont kow how to proceed on this??
(3,249 Views)
Hi ranjini,
Contour (or topographical) maps are usually two dimensional plots with contour lines indicating changing elevations.  I assume that you really want to find either the surface area or the volume of the 3D surface represented by a 2D contour map, correct?
(3,217 Views)
In CWgraph 3D , i could set the contour for a particular intensity or amplitude of the Z axis. contour plots are obviously two dimensional but in this case, the contour  area varies as u set the different levels of the Z axis. i dont have a 2d graph seperately. i think i could make it clear now.
(3,210 Views)
in CWgraph 3d , there is a provision to get the contour for a particular Z plane. this means, it is getting the cordinates of X and y for a particular Z. how to extract it to an array? if i have to write  a program it is possible. but i was just guessing there must be some way to get this in short cut.
thanks
(3,194 Views)
Hi Ranjini,
I'm not able to tell what provision your referring to that gets the X and Y coordinates at a given Z.  Can you explain how your doing this?  The CWGraph is an indicator, not a VI that returns calculations on the data it is given.  If you can try to explain exactly what you have done it would help me to find a better answer for you.  Thanks.
Stephen S.
1 Test is worth 1000 expert opinions
(3,170 Views)
I understand that CWgraph 3D is an indicator. contour plot is drawn by changing the setting of the properties of graph.
hope i could make it clear
and thanks for reply.
(3,155 Views)
i could complete this through matlab script.
Thanking  you
Ranjini
(3,110 Views)
