area under curve of an XY graph with constant non equi-distant x values and corresponding Y values which is dynamic and changing with time
I am trying to find the area under an XY graph. X and Y values are arrays connected to the XY graph.  The X values are the wavelength values which are constant but not equi-distant. The corresponding Y values are intensity values which are changing dynamically with time.  I have used numerical integration. Since numerical integration accepts only equi-distant x-values, I have converted the non equi-distant x- array to equi-distant x array. It is relatively easy since the x values are constant. I simply read it from a constant array. However, I could not determine the corresponding Y values of these equi-distant X values. This is necessary since the numeric integration vi gives correct integral value only if the Y array has equi-distant x values. How can I find the corresponding Y values (Y array) so that I can connect this to the numeric integration.vi. ? I have used polynomial interpolation.vi but it only gives one value and if I put a for loop around it to calculate the whole array, it takes a long time to find 2048 corresponding Y values. I also do not want to fit a polynomial curve to the original data because the nature of the curve changes with time. In short, my question is : how can I find the area under a curve with non equidistant x values?
Also if possible, is there a way to obtain the funtion of the curves created by X and Y arrays? X array is constant and has 2048 index values. Corresponding Y values are changing with time.
Baris
(4,910 Views)
Sound like you need to do a piecewise integration. Find the area under the line between point 1 and point 2, between point 2 and point 3, between point 3 and point 4, and so on. Then sum all these results.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,899 Views)
Using the trapezoid method, the numerical integration is rather direct.
See the attached vi.
You can't get the function described by the X and Y arrays. You need to know the function from start ! However, you can always fit a function to the data. Polynomial curve fitting is quite popular. Of course this is something you could have done : fit a polynomial, then integrate it. With a large number of points (such as yours), the result will not be better than the trapezoid method.
Chilly Charly    (aka CC)
(4,891 Views)
THanks a lot for the vi. It was really helpful.
(4,876 Views)
