arithmetic average with LabVIEW 6.1
Hallo,
I have an array containing six rows and 3 columns. My task is to calculate the arithmetic average of the elements in the columns and add it as a seventh row to the array. How can I do that? I added a txt-file with the array.
Message 1 of 9
(4,110 Views)
I have attached two examples. The first one averages the six values in each column and outputs it in a seventh row of the array. I didn't know if you would want to do more than just an average of the seventh row or not, so I am also adding an example that adds the average every second.
I hope this helps.
Lauren
Message 2 of 9
(4,110 Views)
Hi Lauren,
thanks for the answer. Your idea works, but I need a more generous version:
I have to extract the rows from a 2D-array, compute the arithmetic average of each row and add this value as a seventh column. Finaly I merge the rows together again to one 2D-array and save it to a txt-file.
By the way, it won't have three rows, but more than 20. The VI should count the number of needed rows by itself.
Perhaps someone can help me now.
Arno
Message 3 of 9
(4,110 Views)
I added my VI and the resulting output. What is wrong?
Arno
Message 4 of 9
(4,110 Views)
Here's a simple way to do it, no counting of columns or rows needed.
(Since in the US the decimal separator is ".", I added a step to change this to be able to read the fractional parts. You probably don't need this step if your system is set to "," as decimal separator.)
Message 5 of 9
(4,110 Views)
Quick note: If you use "Read from spreadsheed file", you only need the tiny FOR loop, that's it!
Message 6 of 9
(4,110 Views)
Your problem is shift registers.
Also, why did you transpose an array twice? I was confused by that. Was that on purpose or accident.
See if this works right.
Message 7 of 9
(4,110 Views)
Sorry, I confused "row" with "column" in your description, just transpose as in the attached VI.
(I assume your system is set for "," as decimal separator).
You don't need a huge pile of code for this!
Message 8 of 9
(4,110 Views)
The easiest ways are always the best !!
Thanks for helping me.
Message 9 of 9
(4,110 Views)
