array and for loops
hi all!
I have to perform a calculation inside a for loop and store the
results in an array of integer. My problem is: the n-th result has to
be compared with all the elements already stored in the array during
the previous (n-1)-th interations and then added to array only if it
is not equal to any element in it.
how can i do that?
Yattaman
(2,597 Views)
> how can i do that?
There are two general approaches. The straightforward approach is simply
to loop comparing with the element. You can easily turn this into a
subVI if you like.
If your array gets very large, this will become inefficient and you
might consider keeping the array sorted and using Search 1D array. If
the order is important, keep two arrays, one in the original order, and
the other sorted. Note that the benefit of this wi
ll also depend on how
often you get duplicates.
Greg McKaskle
(2,597 Views)
