array blink indicator
Given: Can't assign attributes for individual elements of an array.
But we can, obviously, have different values for each element of an array.
In attempt to make a blinking progress bar (where only one element is blinking), I:
1) Used an array of color boxes (I think you suggested this in another post).
2) Constructed an actor that blinks a color box.
   a. Parameters are fgd, bgd, blink rate and a reference to the color box to be blinked.
   b. This works for individual color boxes (where I can easily get a reference to them).
3) I can't, and I've tried, find a way to get a reference to an element of an array (that I can then pass to this actor).
Note: I'm not trying to change the attributes of elements of this array, only their values via a reference.
Q: Is this reality? Or is there an entirely different way to do this?
Thanks in advance,
Dave
Message 11 of 20
(2,640 Views)
You take a reference to an entire array of color boxes.  The value property is an array of values.  Change the value of individual elements within that array.  (Replace Array Element).
Message 12 of 20
(2,638 Views)
Thanks again!
Here's the working code. Is this doing a read-mod-write on the whole array? Just to overwrite one element?
-Dave
The reason this could be important is that other threads may be accessing (and wanting to blink) other elements of the array. I can see a way to coordinate this, but I don't want to do that if it isn't necessary.
Message 13 of 20
(2,621 Views)
Yes.  But if you have conflicts because of other stuff accessing it at the same time, you need a better architecture.
I know of at least three options, I'll put them in the order I would use them if it was my project.
1.  Older, but still good.  A functional global variable.  Commands to read an array element or set an array element.  It is a single run while loop where the data is stored in the FGV in an uninitialized shift register.  Because the subVI is non-reentrant, only 1 location can access it at a time.
2.  A data value reference.  Came about in more recent versions of LabVIEW, you pass a reference to the data around,  Use an In Place Element structure to access the data.  It puts a lock on the data so that other locations can't interfere at the same time.
3.  Single element Queue.  Data is in a queue.  Any place that needs it dequeues the array, modifies it, then re-enqueues it.  Other places can't conflict because if they try to read it at the same time, the queue will be empty and will wait for it to be re-enqueued.  I don't think this is used as much now that Data Value References exist.
Message 14 of 20
(2,618 Views)
RavensFan,
Thanks again... three ways of making a mutex. I'll use method (2).
But is it true... that the whole array is read-mod-write?
-Dave
Message 15 of 20
(2,615 Views)
I'd say yes and no.
Certainly for method 3.
With method 1 with the FGV, you could create a command that is modify element and use another input to tell which index you are modifying.  Then you'd just use Replace Array Subset within that case to act on a specific index.
For Method 2, the In Place Element structure has the ability to also read and replace one or more specific indices.
Message 16 of 20
(2,608 Views)
This is working:
Thank you!
-Dave
Message 17 of 20
(2,602 Views)
That will work as long as you aren't trying to do that in 2 or more places at the same time.
That is effectively doing the same thing as what you are doing in message 13.
Now if you wrapped that in a non-reentrant subVI and always use that subVI when setting the value of an array element, you'll be okay.
Message 18 of 20
(2,590 Views)
Maybe I'm beating a dead horse here, but I'd like this color box blink actor to be agnostic to whether the indicator is a scalar, an element in an array, or in the primary circumstance I'm considering, an element in an array of clusters.
As I understand it, the techniques we've discussed require the blink actor to know how the indicator is "declared".
If I could just pass a reference to a single color box to the actor, regardless of how it's arranged, I'd be good. But I don't yet see a way to get that reference if the color box is in an array (I know how to do this if the CB is an element in a cluster or if it's a scalar).
"Giving up" in this case might mean using a variant and then having the actor figure things out. But it seems so unnecessarily ugly.
What am I missing?
Dave
Message 19 of 20
(2,555 Views)
And this use case shouldn't be that uncommon.
1) If I had an array of numerics, where each numeric represents the same process parameter type (temp let's say) measured at different points on a production line and
2) I wanted to use an actor for each element in the array (to update those elements asynchronously to each other) and
3) I wanted the actor to work on scalars or on an array (so I could reuse that code), I'd have the same problem to solve, right?
I must be missing something obvious.
-Dave
PS: Maybe the "scalar" should be an 1D array with only one element in it? That would be a weird work around.
Message 20 of 20
(2,553 Views)
