array comparision
hi all
i have 2 arrays .... i simply need to check if both are same ... if same give me a true and if not a false...
by using the '=' function i get an array of true/false......... what i need is simple just a single true if they are equal and if not a false
any suggestions
regards
Regards
(2,959 Views)
Accepted by topic author nolsqn
Right click on the equals, go to Comparison Mode, then select compare aggregates.
Message Edited by Ravens Fan on 02-16-2010 12:36 AM
(2,953 Views)
hi,
Its just extension of your logic,
see the attached example.
edit : sorry i did'nt see the above msg, it is optimised answer.
Shrek
Message Edited by shrekt on 02-16-2010 11:09 AM
(2,951 Views)
