array comparison with a threshold
Hi
    I want to compare an array with a threshold value and then plot the values of the array which are above the threshold.
Thanks in Advance
Best Regards
RASHID
(4,522 Views)
Accepted by topic author Rashid931
Hi rashid,
  For normal comparison with the thresholds,you have to make use of a for for indexing each elements and comparison functions and a case structure..
For your idea ,i am just adding sample code.
Thanks and regards,
srikrishnaNF
Srikrishna
(4,512 Views)
I would set the values that are below the threshold to NaN (Not a Number), this will prevent the plot from showing those data-points.
Ton
My LabVIEW Ideas
(4,482 Views)
