array constants to excel table
Hi, can someone help me with this.
I currently have 2 arrays of elements.
the elements are given from other files.
we are not getting data from any other devices as time goes. only from a given file.
i want to create a ways to enter these two arrays into an excel file.
For example.
array1=[1,2,3,4,5,6,7,8,9,10] (these array don't necessary have 10 elements all the time)
array2=[11,12,13,14,15,16,17,18,19,20]
my excel table will be
DATE TIME
Name of Array
Column:
X        y
1      11
2      12
3      13
4      14
etc   etc
is it possible to do?
does anyone have an example?
Krispiekream
Message 1 of 11
(4,861 Views)
This is not an excel table, but a text file that you would be able to import into excel.  Build a 2-D array out of the 2 1-D arrays.  Transpose.  Put it into Write to Spreadsheet File.vi.
Message Edited by Ravens Fan on 10-29-2007 08:30 PM
Message 2 of 11
(4,846 Views)
that works.
what if i have more than 2 arrays?
I had, X & Y, that was 2D?
what if i have X,Y,Z....up to 8?
Krispiekream
Message 3 of 11
(4,822 Views)
Just add to the build array...
Message Edited by Steve.Briggs on 10-30-2007 01:14 PM
Message 4 of 11
(4,818 Views)
If you have the Report Generation toolkit, you can easily bring the data into Excel once you've made it a 2D array. See attached.
Message 5 of 11
(4,803 Views)
the last file you sent was in version 8.2.
can you save it for previous version?
i can open 7.0 or 8.0
thanks
Krispiekream
Message 6 of 11
(4,801 Views)
Try this. I saved to 8.0.
Message 7 of 11
(4,796 Views)
it said that i am missing the following subvi
Excel Easy Table.vi
Excel Easy Table(num).vi
Excel Bring to Front.vi
can you help?
Krispiekream
Message 8 of 11
(4,792 Views)
Those VIs are part of the add-on called the Report Generation Toolkit. This is an add-on that has to be bought. Using the Write to Spreadsheet function is simpler and faster than using the toolkit. The toolkit uses Excel's ActiveX properties and methods to create a native Excel file instead of a tab or comma separated text file.
Message 9 of 11
(4,786 Views)
As Dennis said, you probably don't have the Report Generation toolkit. If you wanted to output the data specifically to an Excel file, you'd need to get that toolkit. And that would be something you'd do only once you're ready to generate the report, not while you're acquiring data. Otherwise, write to a simple spreadsheet file.
Message 10 of 11
(4,783 Views)
