array elements equal to each other?
Maybe a very simple question but i haven't found the answer here...
I have a 1D Array with let's say 4 elements, and if all elements are equal to each other
(1,1,1,1)  then it should return true
if one element is other then the rest
(1,2,1,1)  it should return false...
How to build this simple?
Thijs
Message 1 of 8
(7,710 Views)
I got this thus far...?
But maybe there is something more simple?
regards,
Thijs
Message 2 of 8
(7,705 Views)
Hi Thijs,
you need to compare one element of the array with the remaining ones:
To your own approach:
- RubeGoldberg due to indexing the same element of the array in each iteration
- RubeGoldberg due to using a loop where polymorphism will do the same
- wrong labeling of the output: you need to AND all booleans, but not ORing them
- the AutoCleanup tool is pretty good at such small snippets…
Message 3 of 8
(7,704 Views)
Nice,
But i came to realise that there's a bigger challenge:
Input1: 1D array of elements (all elements)
Input2: 1D array of elements consisting of 2 elements which are allowed.
Output: True if the two elements are in the array or if all the elements are equal
Output: False if the two elements are not in the array.
Input1: (1,1,2,1,1)
Input2: (1,2)
Output: True
Input1: (1,1,2,1,3)
Input2: (1,2)
Output: False
Input1: (1,1,1,1,1)
Input2: (1,2)
Output: True
Thijs
Message 4 of 8
(7,684 Views)
Accepted by topic author ThijsBoeree
Hi Thijs,
so you need to compare if each element of array1 is a member of array2:
Did I get this right?
Edit: the label of the output should be just "all elements of array are members of array2"
Message 5 of 8
(7,680 Views)
Wow that's fast.
Thanks!
Message 6 of 8
(7,670 Views)
Hi Thijs
This is not clearly defined. What happens when array1 consist just of zeros and array2 contains [1, 2]? Giving your description you want output=TRUE (all elements are equal!) - my snippet will produce FALSE in this case...
Either redefine your question or modify my snippet! 😄
Message 7 of 8
(7,665 Views)
Then my question was not right defined, because it works perfectly!
Regards
Message 8 of 8
(7,653 Views)
