array help
Hi
I can not find the thing in the rectangular in below picture. Please some one navugate.
(3,816 Views)
Accepted by topic author uni-pixel
"built array" from the array palette.
(3,811 Views)
That is called "Build Array" and it is in the Array pallet when you drop it onto the diagram it will only be a single input.
Grab one corner and resize it as big as you need.
=== Engineer Ambiguously ===
(3,809 Views)
Hi altenback
Build array is look like something else with one input and output.
(3,808 Views)
You can resize it for as many inputs you need.
(3,784 Views)
