array insert limitation
hi,
          k finally insert array is best to use?
Message 11 of 13
(1,364 Views)
@GokulGKM wrote:
hi,
Is "k" a word?
If you read any of the most recent messages, why would you thing Insert Into Array is the best to use.  They clearly showed Build Array is better, and using Indexing Tunnels is better still if your code can be arranged to use them.
Message 12 of 13
(1,351 Views)
ok thanks,
Message 13 of 13
(1,328 Views)
