array into cluster
How do I input an array into the middle of a cluster?
Message 1 of 21
(4,107 Views)
For loop or something more elegant?
Message 2 of 21
(4,103 Views)
Hi exo,
can you explain a little bit more? Thanks
Mike
Message 3 of 21
(4,101 Views)
Like what?
You have to be more specific. Cause if you use "bundle" you can do that!
Software developer
www.mcm-electronics.com
PORTUGAL
Message 4 of 21
(4,101 Views)
I have an array of strings that needs to become part of a cluster. If I bundle an array of 10 elements into position 3 in the cluster will it fill in elements 3 to 12?
Message 5 of 21
(4,098 Views)
The example it's not pretty. But see if it helps!
Software developer
PORTUGAL
Message 6 of 21
(4,097 Views)
Nope, Sorry. Each element in the array has to become an element in the cluster. The array cannot be an element in the cluster.
Message 7 of 21
(4,066 Views)
Index array and bundle by name will let you choose which index goes into which cluster element.  If there is a 1:1 mapping of index to cluster elements and the cluster is all of a particular data type there is cluster to array and array to cluster fuinctions in the vi pallette.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 8 of 21
(4,062 Views)
The array elements have to go into the middle of the cluster.
Message 9 of 21
(4,059 Views)
It does not really help if you keep repeating cryptic messages.
A cluster has no "middle"!
Why don't you attach a VI that has reasonable input values as control defaults and an indicator with the desired cluster, again containing the desired outcome as default value. This way we can easily see what you actually mean. Thanks! 🙂
Message 10 of 21
(4,030 Views)
