array into varient
I am trying to pass array of integer from one main vi to sub vi. The array i convert into variant data type. I want to reconstruct the data using variant to data function. I am not able to retrive the array irrespective to data type i set( int or array of int to variant to data ). Wondering what is going on.
Message 1 of 12
(5,949 Views)
Can you give an exaple of your code that doesn't work?
You need to supply the data type to convert to on the Variant to Data node (input on the top will accept anything).
Message 2 of 12
(5,942 Views)
Is there a particular reason you are using a variant? Also, as suggested post your code so we can see what you are doing.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 12
(5,927 Views)
my bet is he's passing different types of data....Smiley Happy
Spoiler
Message 4 of 12
(5,908 Views)
That's a good point.
Are you getting an error when you try to convert from a variant?
Message 5 of 12
(5,905 Views)
probe shows input is array inside the variant but out put is null
Message 6 of 12
(5,893 Views)
Spoiler
Then he will need some key to indicate how the data should be decoded. I was asking because if he is simply passing the array as a variant because it sounds useful is not a very good reason. Polymorphic VIs are more appropriate. Variants are good for generic messaging schemes.
Mark Yedinak
LabVIEW Champion
Message 7 of 12
(5,888 Views)
Post your code. It is near impossible to give you good advice without seeing what you are actually doing.
Mark Yedinak
LabVIEW Champion
Message 8 of 12
(5,887 Views)
show the code......................................
Spoiler
did you signify the type of data used on the "variant to data function"?    Smiley Surprised
Message 9 of 12
(5,885 Views)
time to pull out the crystal ball again.....I think I have a few more dollars left in my account for the psychic network
Message 10 of 12
(5,872 Views)
