array of 15 elements: with every measurement delete first element and append actual value
Hi everybody,
I would like to analyze my measurements in realtime as I control a device with the results of the analysis.
Therefor I would like to continuously calculate the mean value of the last 15 values.
I know how to create the array of the first 15 elements, but how can I (after I got the first 15 values and calculated the first mean value of them) delete the first value and append the actual value with every following step? I tried it with the "Replace Array Subset", but it doesn't work the way I do it: (. Can I do all these steps within one while loop?
I think it's not that difficult, but I don't know any solution right now: ( I would really appreciate anybody's help or a simple example, I work with LV 8.0.
Thank you very much in advance.
Steffi
(4,874 Views)
Hi steffi,
you can use the "Rotate 1D Array" vi. See the attached example.
Mike
(4,871 Views)
This is just another method.
Vikas
(4,864 Views)
Steffi,
I posted a circular buffer example using queues on your other thread.
Lynn
(4,847 Views)
Yet another method. This uses one of the Point-by-Point functions (see attached images)
(4,838 Views)
Hi Steffi,
this will work without any shifting of elements in memory:
Message Edited by GerdW on 04-01-2008 05:59 PM
(4,833 Views)
Wow, thanks to everybody.
I will have a closer look at your examples tomorrow!
Thank you very much!
(4,827 Views)
