array of Ring to string value for creating a table
I want to convert an array of ring to string and generate a table from it.Smiley Indifferent
But using property node for converting each ring is changing all the value of the table!Smiley Surprised
each array represents different register!hence required to change  for different array!
i am hereby attaching a  Vi!
(3,248 Views)
Accepted by topic author Krisna
I think this will help you.
See attached VI snippet.
(3,234 Views)
How about this simple solution? Array of a ring control to Array of string.
/Y
Message Edited by Yamaeda on 04-13-2010 08:36 AM
Qestit Systems
Certified-LabVIEW-Developer
(3,225 Views)
Thanks it worked!:smileyvery-happy:
(3,209 Views)
