array of cluster to table
Any  examples of creating a table from an array of clusters??  There is an example for going from a table to array of clusters.
Thanks.
(6,469 Views)
Hi Mark,
thoat would be a straight-forward way to convert an array of clusters into a 2D-array of strings (aka "table"):
 http://forums.ni.com/ni/attachments/ni/170/620569/1/check.png
(6,462 Views)
Maybe I should have explained more.  My understanding was you used a cluster when you want to bundle elements of different types...ie strings,booleans, numeric.  I'm trying to create a pass/fail report to display to the operator at the end of the test.    I tried to follow your example but you can't create an array of diffrent elements.
Here is what I have:
(6,457 Views)
Accepted by topic author MarkDavid
Mark,
The table control wont take different types of data. Your best bet is to convert everything in to string.
Hope this helps.
regards,
aCe
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(6,439 Views)
That was the piece of the puzzle I needed.
Thanks everyone.
(6,432 Views)
