array of culster
Hi all :
please see attach file ,, I bulid array (0-15) of cluster each cluster had 6 number SGL type .. ,, i want to separate this array  and culster
but according to me idea if i build  array (0-15) of cluster each cluster had 6 number SGL type  , its will be 16*6 table
but when i used my  vi , you can see that i get only 8 cluster instead of 16  : why ?
thanks
(2,971 Views)
You have 9 clusters (0-8) not eight and you have 9 because that is the default for the Array to Cluster function. Right click on it and  select Cluster Size.
(2,962 Views)
Hi elyan,
all of your elements are there. see the attached file.
Mike
Message Edited by MikeS81 on 03-02-2008 03:11 PM
(2,960 Views)
