array of strings to multiple string controls
I'm parsing a query response from a noise generator - it comes back as "1234,2345,3456,4567,5678,6789,7890,8901,9012,0123".  Basically, one long string of 10 4-digit values, comma separated, is returned.  Using the string Match :Pattern (in a loop) I've parsed the large string into an array of 10 4-digit strings without commas.  Now, I have 10 indicators (each representing one of the 10 values) that I want this info to go into.  I could (one-by-one) stuff the array information into each of these indicators.  However, I'm wondering if there is a loop-ish approach where maybe all the indicators get grouped into a cluster and the cluster order is the iterator that indexes into the source array.
Any suggestions?
(3,241 Views)
You could use Spreadsheet String To Array to get an array of numbers, and then Array To Cluster to build a cluster from that.  Several considerations though.. If there is a blank field (2 delimiters in a row), the output would be 0.  Also it will output an array with as many elements as it can parse from the input string.  But since you specify a cluster size in Array To Cluster, your cluster would always be the right size though, so maybe not so much of an issue?
Here's an example anyhow..
(3,236 Views)
Maybe you can just use a plain array indicator directly. Anything wrong with that? It reduces diagram clutter! 🙂 You can always add free text labels outside as fake element labels.
If your indicators are scattered all over the front panel, use a single "index array", resized to 10 elements.
The attached example (LabVIEW 8.0) shows both ways.
(3,228 Views)
And as a third option (although I would personally prefer any of the other two) you can create a reference for each control, build them into an array and auto-index that array and the array of strings in a for loop and use the Value property to set the strings.
This is good mainly if you don't want to use a cluster or array, but even in this case, I would probably use Altenbach's Index Array method.
___________________
Try to take over the world!
(3,208 Views)
