array point
Hello:
         I have a C demo as below,which uses a byte array point as parament and convert it to short.Now I want to use it in LabVIEW,how can i do?
         The LabVIEW picture I have catched.The input and return value's type I need in LabVIEW is I16.
        Thank you.
BYTE * PixValue;
void CDMDControlDlg::OnSetDMD()
      // TODO: Add your control notification handler code here
      //BYTE * PixValue = new BYTE[98304];
      for(UINT i = 0;i<98304;i++)
            PixValue[i] = 0xFF;
      m_ddcobject.MemToFrameBuffer((short *)PixValue);//return is also a I16
      m_ddcobject.LoadToDMD(17,1);
      //delete []PixValue;
Message 1 of 1
(2,924 Views)
