array size
Accepted by topic author labview99
Hi 99,
@labview99 wrote:
I have tryed to do what GerdW tells me and the lengths continue being different. One 36 and the other 37
My magic glass ball says:
From the quality of your posts and shown code you probably used InsertIntoArray instead of ReplaceArraySubset somewhere in your code…
Message 11 of 18
(2,793 Views)
The problem is in the last frame in the case "false" whith the function array size, that the length is 37 and it must be 36.
Message 12 of 18
(2,788 Views)
Gerd's crystal ball is polished up quite nicely today!
Providing your attempt could have gotten you the answer 4 or 5 messages ago.
Message 13 of 18
(2,781 Views)
Hi 99,
Yes, the problem is exactly in the last frame. My magic glass ball was right… 🙂
You did not implement any of the suggested improvements so far: why not?
Message 14 of 18
(2,780 Views)
YESS!!!
You were right GerdW, I was using Insert Into Array instead of using Replace.
Thank you so much for your help and for posting the code!
Message 15 of 18
(2,779 Views)
Please take the training courses as GerdW has pointed out many times in your other posts. And please improve your posts like GerdW has also described many times.
Certified LabVIEW Architect
Message 16 of 18
(2,775 Views)
Just as GerdW suspected, that's exactly where you used "Insert Into Array" instead of "Replace Array Subset", which you properly used in other locations.
They *do* look awfully similar when their labels aren't visible.
-Kevin P
Message 17 of 18
(2,773 Views)
@GerdW wrote:
I simplified the first frames of that huge sequence:
Or even simpler (Small part)....
Message 18 of 18
(2,732 Views)
