array spreadsheet array
@MscSarat wrote:
I seem to be getting the result..
But when i try to display the summed up array in a spreadsheet array text file..
it tells that the 'write to spreadsheet file ' array is broken.
can u help me on this??
If you double-click the "write to spreadsheet file" and its run arrow is broken, you need to reinstall or repair the LabVIEW installation. Press the broken run arrow of "write to spreadsheet file" and tell us exactly what it complains about.
Did you ever try to edit it yourself?
Message 21 of 32
(2,873 Views)
Message 22 of 32
(2,873 Views)
Don't attach my old code I posted earlier! That is just a waste of bandwidth and does not contribute anything new.
Show how you are writing to a spreadsheet file!
Message 23 of 32
(2,867 Views)
well, i have wired from the input of the( Array max and min ) to 'write to spreadsheet file' in the attached file..
Message 24 of 32
(2,863 Views)
That doesn't help. What input? To what terminal of the Write to Spreadsheet File? Through the loop?
Please show us your code. Save what you did and upload it.
Message 25 of 32
(2,853 Views)
What does that mean? What is broken? Do you get a broken wire when you try to hook it up? Is the subVI itself broken? Do you get an error during run time? What is the exact error message? What is "it" that tells you all this?
Message 26 of 32
(2,834 Views)
THe code works fine now... there was some problem in installation. I reinstalled it, So now it works fine.
Many thanks for your help.
Message 27 of 32
(2,788 Views)
Great! 🙂
Message 28 of 32
(2,770 Views)
I have zoomed in the intensity graph and focussed on my subject(solar cell) . Now i have to rescale the x axis from ZERO to XXX and even for Y axis.
And also display the maximum value of the pixel only in terms of newer scale and not the old scale. How do i go about this.
Secondly,  i need to retrieve a particular array element using XY coordinate. I tried but getting some errors.
Please help me solve these 2 problems.
I have attached the VI for your reference. and i am using labview 9.0 in my laptop and 8.0 in lab.
Thanks in advance.
Message 29 of 32
(2,743 Views)
Please ignore the second part of the question. I have some how got through it.
kindly Help with the first part of the question.
Thanks in advance.
Message 30 of 32
(2,730 Views)
