array subset using condition
I have a 2D array which i want to split into 2 subset using a condition. Say i have
X              y
125         1.5
585         1.1
798         1.0
1054        0.75
3586        1.12
i need to split the array to two subsets with thos eof below 1000 and above 1000.
help please...
Message 1 of 15
(7,635 Views)
What have you tried so far?  Attach your work.  This sounds like homework.
This is a relatively easy problem.  We can point you in the right direction but don't expect us to do your homework for you.  Take a look at for loops and tunnel indexing
Message 2 of 15
(7,625 Views)
no it is not.
it is a part of a whole analysis program im making.
You see i have summary of frequency peaks  which changes every signal i input. i need a subset array for those peaks recognized as below 1000 and above 1000.
Message 3 of 15
(7,616 Views)
Hi camr,
so you should change that fixed "index" input to some variable value - using a search function would be a good idea…
Message 4 of 15
(7,602 Views)
@GerdW wrote:
Hi camr,
can you suggest a search function?
i tried using search 1D function but it wont work as my array values never coincide with 1000. its index location also varies.
Message 5 of 15
(7,581 Views)
Threshold 1D Array will do what you want…
Message 6 of 15
(7,575 Views)
threshold array wont work as I have a 2D aray. I have tried that as well and doesnt work.
Message 7 of 15
(7,570 Views)
But it will work on your 1D X value column…
Message 8 of 15
(7,566 Views)
yes it will work but the value is wrong... thus it wont give me my desired output
Message 9 of 15
(7,553 Views)
Message 10 of 15
(7,552 Views)
