array summation <HELP> !!
Basically i have 1 d array which consisnts of thoudsands of numbers in it.
But i want to do the summation on every particular number pattern. is there a way to do it?
<EXAMPLE>
in example i posted is 1D array consists of 9 elements , if i join it to summation , my answer will be 45.
but what i want is i want to know the summation of every 4 values and come out in another array.
*reason i need it is bcuz i have a spreadsheet recorded the accummulated values (thousands of them) of differnet days and i want to rearrange them into total of every single day accumulated values *
(3,142 Views)
Try this. (Edit: The primitive used here is Delete from Array)
Good luck
(3,135 Views)
(3,130 Views)
P@Anand I tried ur way, it kind of work but the result come out is not the value. :S
(3,116 Views)
How does a image of an indicator prove or disprove your statement. We don't know what the input is! That image has zero information content.
If you have code that you think does not work right, attach the VI and some typical data. Tell us what result you expect.
I would also strongly recommend my code above. It will be much more efficient. Have you tried?
(3,110 Views)
(3,106 Views)
If your input has 9 elements, only 8 are used, because the last group is less than 4 elements. 9 is not divisible by 4 without a remainder.
If you want to round the size up to the next mutiple of four, do it, for example as follows:
(And please stop attaching useless pictures. We know how an array with two elements looks like 🐵
(3,100 Views)
