array to spreadsheet
I have two seperate arrays and would like to save the file to a spreadsheet.  From the configuration that I have, I get one column instead of the two columns that I require for the two arrays.  Any help is greatly appreciated.  (I am working in LabView 8.2).
Thanks.
(2,998 Views)
Accepted by topic author hiNI
right click the build array and uncheck the concatenate inputs... then wire your array to the 2D data input on the write to measurement file!
(2,995 Views)
