array
Hi, All
I have a questions about the array.
if I have data and need to concentrate to a aray but i didn't know how many elements will  come.
like this
2000 0
2010 10
2020 20
2030 30
how can I result it ?
thanks
Message 1 of 8
(4,953 Views)
It would be very helpful if you can explain your question... I have not understood it clearly.
thanks
Message 2 of 8
(4,941 Views)
thanks
Message 3 of 8
(4,940 Views)
sorry , let me explain clearly. ingore my first silly question
pls see the attachments ex1 and ex2 for example which i need
based on different data,  the output is different. the final number is different, but can be controled by another function.
 and i have a vi, but there are some problems, pls see as well.
Message 4 of 8
(4,932 Views)
Hi srt,
I noticed that the only difference between ex1.txt & ex2.txt is that one ends at 2080 and the other at 2090.
Do you mean that the number of elements may change or that your array is dynamic? (ie: size of array may change based on acquisition)
I am not sure what you want to do. Can you describe what you want to accomplish?  A global overview without going into the LV details.
Ray
Message 5 of 8
(4,920 Views)
yes, the array size is dynamic, but the first question is how to append the array into the string.
i try to use the format into string function, but it didn't support the array.
 thanks
Message 6 of 8
(4,915 Views)
try to use the Array To Spreadsheet String from the String-Palette to convert a 2 Dim Array to text.
Hope that helps,
Ciao TPoint
Message 7 of 8
(4,912 Views)
TPoint beat me to the punch 😉
Here is a link that describes String Array to Spreadsheet :  http://forums.ni.com/ni/board/message?board.id=170&message.id=148030
Even if you do not use an actual spreadsheet, it will delimit the data by comma or tab.  Very useful tool 🙂
Thanks TPoint.
Ray
Message 8 of 8
(4,908 Views)
