array
Hi everbody,
I have a array. for example,
index 0 is 20 (element)
index 1 is 10
index 10 is 30
I would like to shift index of the array and add a new number to index 0 and 12. for example,
index 0 is new number (0)
index 1 is 20
index 2 is 10
index 11 is 30
index 12 new number(100)
How can I do it?
Thank you.
(3,662 Views)
Use "build array" with three inputs. Middle for array and Top/bottom for the new elements.
(3,658 Views)
Rotate Array followed by a Replace Array Subset should do it.
(3,631 Views)
That would keep the array the same size. The way I understood, the new array should be larger by two elements.
(3,608 Views)
