arrays as input to shared library function
I've been playing with calling LV VI's using matlab.
So I built a simple VI which gets an integer as input and multiplies it by 10, I then put it in a shared library and called it from matlab- so far so good.
Now I tried doing the same with an array- I want to send an array to the VI and have it multiplied by 10, but when I build the .h file it seems that the function expects to get both the input array AND the output array as inputs.
so how can I build a shared library VI that gets an array (of a constant size if it matters) and multiplies it by 10?
thanks!
(4,287 Views)
Accepted by topic author shayelk
A function in a DLL can only return a scalar, not an array, regardless of which languages are used. To return an array, instead the caller allocates the array, passes a reference to the array to the DLL, and then after the function call the referenced array contains the new data. This is why there are two parameters - the input array (actually a pointer to it) and a pointer (reference) to the output array. You need to change your MATLAB code, there's nothing you can do about this in LabVIEW. EDIT: Also note that this allows re-use of the input array as the output, if you want, by passing a reference only to the input array, and then modifying that. You can do this in LabVIEW by configuring the array parameter as both input and output.
(4,271 Views)
thanks nathand!
I tried building the library with what you said in mind, but when I tried loading it using matlab I got the following error:
Error using loadlibrary (line 422)
Failed to preprocess the input file.
Output from preprocessor is:math.h
C:\Users\*********\math.h(1) : fatal error C1083: Cannot open include file: 'extcode.h': No such file
or directory
the "loadlibrary" matlab function worked just fine with the scalar VI, any Ideas why it won't work with the array VI?
(4,247 Views)
First, make sure you configured the array parameter(s) as passed by array data pointer - any of the other options use LabVIEW-specific datatypes that may cause problems for Matlab.
If it still builds a .h file that includes extcode.h, you can either tell Matlab where to find that file (I'm sure there's a setting somewhere for the include search path, although I don't know where) or you can edit the .h file to remove the reference to extcode.h and replace any LabVIEW datatypes with equivalent C data types (sort-of - the reason LabVIEW defines its own types in extcode.h is to ensure consistency in the size of datatypes since C doesn't actually have a standard).
If that's not clear, attach the .h file or copy its contents into a reply and I'll try to help.
(4,220 Views)
