arrays in for loops
I am trying to put values into an array using for loop. My requirement is to insert the value into the output array only if i mod 2 is equal to zero. Otherwise, I do not want to pass anything to the array. The problem arises because I cannot leave the output tunnel unwired in the 'False' condition of the case structure. So I tried wiring a constant value of 0. Now my result array has zeros also. How can I modify this VI so that I get an array like 0 2 4 6 etc?
Thanks in advance
(2,924 Views)
Wouldn't it be easier to simply multiply [i] by two and run the loop for only half the current number of iterations?
(You have LabVIEW 2012, so there is also the condtional output tunnel that could do what you want.)
(2,918 Views)
That is a sample code I attached. Not the actual problem I am working on. I want to pass a value to the output array only if the case condition inside the for loop is true. Otherwise, I do not want anything to be passed to the array. Kindly help
(2,910 Views)
Accepted by topic author annakurian
I already mentioned conditional tunnels. See here for details. See how far you get. 😄
(2,904 Views)
Thanks a lot for the reply. I tried using the conditional output terminal on the for loop and it seems to work 🙂
(2,898 Views)
