arrays
Yes sir, with the impulses characteristics. Fall time, frequency or period, etc.
I would have use a DAQ, but here no one wants to buy one.
Message 11 of 21
(870 Views)
The size of the array is determined by the sample input. If you want several pulses and each has a random amplitude, use the function inside a for loop as you had originally. You can use a shift register with a build array function to create an array with multiple pulses or pass the 1D array out the for loop and convert the 2D array to a 1D array with the Reshape Array function.
Message 12 of 21
(863 Views)
Yes, that is what i thought would work.
The problem is that i can not set the Array out of the For loop, it is not filled with random amplitudes.
I Tried to convert from a 2D array to a 1D array aswell, but it didnt work, it only captured the first value in the 1D Array ... very frustrating.
Since i have changed the samples and width, it can be filled with the same amplitude inside the array, but i can not have different values.
Maybe i am not expresing myself correctly, sorry to bother.
Anyway, if you have further ideas i am reading,
thanks.
Message 13 of 21
(852 Views)
With the pulse pattern.vi you only generate one step.
Is that what you want to achieve or do you want to multiply it at random?
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 14 of 21
(840 Views)
I would like to miltiply it at random.
Because then i have to program the estadistic of this, when will it happen. And that will be easier if i can generate it randomly.
Thanks.
Message 15 of 21
(835 Views)
In your posted example, you in fact do have a 2D array with random values. Expand the indicator so that you can see more of each row.
In any case, here's a simple mod with a shift register.
Message 16 of 21
(833 Views)
Can you do it for 2010 version pls.
Thanks.
Message 17 of 21
(827 Views)
Message 18 of 21
(824 Views)
mmm not working. Wait, it says that should be version 11.0.1
Sorry for the mistake.
thank you.
Message 19 of 21
(821 Views)
Sorry. I saved to the wrong version. Try this.
Message 20 of 21
(817 Views)
