arrow indicator: going up or coming down depending on signal derivative
Hello, Experts,
How do I create an arrow indicator going up or coming down depending on my signal direction?
Suggestions will be appreciated.
CK
(2,919 Views)
Depends on how fancy you want it to be. You could use something simple like a Pict Ring and have it contain two elements: the first being the arrow up picture and the second being the arrow down picture. You can then set the value of the Pict Ring programmatically. You could also use a customized boolean indicator where you change the image of the "on" and "off" states. Just a couple of ideas.
(2,902 Views)
thank you.  tried the custom boolean indicator.  worked like a charm.  the question is how i can find a beautiful arrow(up and down).  😃
(2,889 Views)
There's always Google...
(2,886 Views)
