arthimetic operation on complex numbers
how i can do arthimetic operations on complex numbers in array?
Message 1 of 10
(4,116 Views)
A duplicate post of http://forums.ni.com/t5/LabVIEW/convert-array-components-to-re-im-values/m-p/2044628
which ironically he had marked as Solved.
Message 2 of 10
(4,113 Views)
I would not concider this a duplicate.  He is asking something else.  It looks like the same program, but we are at a different part now.
oiuuhjoi, what kind of operations are you trying to perform?  Most of the numeric primitives can already handle arrays.
Message 3 of 10
(4,106 Views)
i dont need to convert 2d array to complex numbers
i need to do arthimatec operation on complex no.
if you understand you discover thats is 2 diffrent questions Smiley Mad
Message 4 of 10
(4,104 Views)
exponential,plus,minus etc
Message 5 of 10
(4,101 Views)
Accepted by topic author oiuuhjoi
The standard numeric pallet operations should work for you.
Message 6 of 10
(4,093 Views)
Hi oi,
did you even try to use some arithmetic functions on complex numbers?
Message 7 of 10
(4,088 Views)
@GerdW wrote:
Hi oi,
I think it's coming more down to the OP didn't know the functions would work with arrays.
Message 8 of 10
(4,084 Views)
Hi crossrulz,
I think it's coming more down to the OP didn't even tries to use those functions, regardless of scalar/array or INT/DBL/CDB...
Message 9 of 10
(4,080 Views)
Well, I think that part is obvious.  We mostly learn by trying.
Message 10 of 10
(4,068 Views)
