ascii to I16
Wayne.C wrote:
Dennis,
I think the tab "-->" characters were added to the post to differentiate first and second read data.
Yeah, I think you are right. Then it appears that there are two data bytes and two null characters
Message 21 of 23
(1,127 Views)
Accepted by topic author RachtheSabu
From what I gather, it looks like you expect the result
FFFE -> 0000
and get something like
00FF -> FE
My first suspicion is that your delay may be a little short.  The leading 00 you see is probably the tail of the previous query.  If you flush the buffer, this would dissappear but there is probably an underlying cause (ie. short delay). It also appears the buffer on the robot is limited to 3 bytes, since there appears to be some 00 values dropped.
We are all guessing here, posting your complete code (both queries) would be helpful.
Message 22 of 23
(1,127 Views)
Flushing the buffer and reading in only 2 bytes was the winning combination.  Thank you for all your help!
Message 23 of 23
(1,113 Views)
