ascii to deimal conversion
hey i have a device sending 2 bytes of data from RS232 port,i have set the display at hex display ,when i apply that to hex string to number function its not converted, may be due to the result not in normal mode????.can any one tell me how can i convertthe ascii data to decimal data??
(3,325 Views)
use typecast with the correct type (e.g. U16 or I16). The display setting is just cosmetic and has no influence on the underlying data.
(3,318 Views)
Here's an example:
Message Edited by altenbach on 08-20-2007 11:18 AM
(3,312 Views)
hey altenbach
thanks for the help
does this convert signed numbers whose ascii's are being generated into decimal??
i mean how are the signed numbers manipulated?
thanks
(3,310 Views)
If you want signed numbers, make the diagram constant into I16 representation (right-click).
Numerics are internally always binary.  "decimal" for numeric indicators is just a cosmetic property. If you have a formatted string, you need to know the format it is supposed to be. If you have a binary string as in your example, you just need to know the correct datatype and you need to ensure that the byte count matches.
(3,307 Views)
ok will try it.
thanks for the help
will ask you if i get any problems 🙂
regards
sdi
(3,301 Views)
