assigning memory on windows os crashing labview app
Hi
I must be doing something really stupid and very easily crashing my pc by writing only few functions in labview!
I want to pre-allocate memory of 5GB at the start of application. So I used simple initialize function to create 2d array of NaN dB points as shown in the image.  I have 8GB of memory but the error popped up as shown in screen. And I only tried 1GB as shown in image. Could I not have this pre-allocation?
ATE and Labview Consultant
https://www.easybodge.com
(3,201 Views)
@k-waris wrote:
Hi
Are you running LabVIEW 32-bit? You can't allocate that much memory with a 32-bit operating system or in LabVIEW 32-bit.
(3,187 Views)
Guaranted 64 bit os and Labview!
(3,153 Views)
What happens if you wire the equivalent number directly instead of computing it?
Bill
CLD
(Mid-Level minion.)
(3,055 Views)
Hi k-waris,
Well, we cannot see which value you used for channel count.
But still then you want to create a 2D array of (atleast) 1G*1 of DBL, which needs 8GB of memory.
With any OS and other software running I guess it will be hard to have 8GB continuous RAM available!
(2,969 Views)
