associating a plot with a specific y axis on a multiple y axis waveform graph for scaling purposes in LV 6.1
Hi
I have a mulitple y-axis (2 in fact) waveform graph with 6 plots, and I want to assign some plots to one y axis and some to the other, programatically using the property nodes. At present, I cannot seem to create an association between a plot and a y -axis.
Multiple y-axis examples seem a bit thin on the ground in the help. I guess it's something to do with active plot and active y-scale, but nothing i've tried yet has worked. I'm using LabVIEW 6.1 on windows 2000 prof. I'm assuming that it's possible and that i'm just missing something.
Thanks in advance
(3,740 Views)
Hi
The properties which you need are:
1. active plot
2. Y scale index (Plot>>Y scale index)
See the attached example.
Luca P.
Luca
(3,740 Views)
Many thanks, just what I was looking for and couldn't find!
Thanks again
timpy
(3,740 Views)
