asynchronous call
Hello all,
                         Suddenly i encountered one strange problem in asynchronous call to rentrant VI, I have a reentrant VI which will read the data from TCP & write to the database,Now i have two method to implement this.
#1. Using property & invoke node(Image is attached).
#2 . Using asynchronous call(Image is attached).
In both the method opening of database is same but problem is, in method 1 everything is working fine but in method 2 path of database is going wrong. I opted for 2nd methos because LAbVIEW suggests this.
Can anybody tell me where is going wrong
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 10
(5,009 Views)
What is the issue? That the path to the DB.mdb is different?
I understand, that you are using the same subVI for both approaches. Correct?
What is wrong with the path to DB.mdb in version 2?
Norbert
Norbert
Expert: Geometry
Message 2 of 10
(4,984 Views)
It's not the classic problem of "My path works in LV but not in compiled .exe"?
When using Db's i like to use .UDL files for connection info, i tend to get less problems with them and it's easy to change database connections.
If you're using a Strict VI-ref, why not connect it to a property node and get the path that way? 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 10
(4,972 Views)
Hi
--Ranjeet
Message 4 of 10
(4,948 Views)
Hi Yamaeda,
                                   Actually this my normal & effiecient way to access database in .exe also. for mdb file i always like to avoid the udl file as this is extra (Redundant). I am using relative path for accessing database.
      Can you please explain how can i implement this. a snapshot will be great. Only database path is going wrong(i hope you know this)
--Ranjeet
Message 5 of 10
(4,946 Views)
Who says that the path is invalid? The Open Database function from the Database Connectivity Toolkit?
If so, what IS the path (use probe/path indicator/popup dialog)?
Norbert
Norbert
Expert: Geometry
Message 6 of 10
(4,908 Views)
Hi Ranjeet,
Asynchronous calls can't be made on reentrant VIs. It just does not make sense because you don't know which reentrant instance of the VI is created/run, and when it is.
I guess this is the very reason of why it does not work. Also, asynchronous calls must have a 0x80 or 0x100 option (when opening the reference) to be properly run.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
Message 7 of 10
(4,898 Views)
Eric,
you are correct with your observation regarding reentrancy. What i wonder is, that the OP seems to make it run with option 0x8 and NOT getting an error. So i am really confused since this should not be possible....
So i presume that the screenshots are showing old/invalid code.
Norbert
Norbert
Expert: Geometry
Message 8 of 10
(4,889 Views)
hi
--Ranjeet
Message 9 of 10
(4,855 Views)
HI Eric.M,
You said ,
please tell me why this application path directory is showing invalid path if i am calling my VI asynchronously.
And one more thing i think that both the method is for parallel execution of same subvi.
But in help file its mentioned that asychronously calling a vi is faster than.
--Ranjeet
Message 10 of 10
(4,854 Views)
