asynchronous data array
I have an transducer inside a nest of five while loops. The transducer is
pre-set with initial parameters such as frequency. At turn-on, it collects
data and then exits into the next outer while loop checking to see if a parameter
has been changed and if so, it will go back into the innermost loop and collect
new data. This process repeats untill all possible combinations of parameters
are tested and data is gathered. There can be several hundreds of data samples
collected. How do I build an array of this data and output it when all possible
samples have been taken?
(3,183 Views)
Hi Fred
You can Enable Indexing as the data wire leaves each while loop. If you do this for 5 while loops you will get a 5-dimention array
of data produced at the final loop.
Tim
(3,182 Views)
