at-dio-32hs
I've tried to install my At-DIO-32HS card, on my computer under Win Nt and with labview 6.i and Ni-daq 6.8.1 but I was not able to configure it.
I tried to refresh MAX or to install another time NI.daq, but AT-dio-32HS didn't appear under devices, and when I'v tried to create a new device from MAX I saw AT-Dio-32F only between the choices.
What can I do?
Thank you,
Paolo5
(2,703 Views)
Here are a few KnowledgeBase entries I found by searching the ni.com support pages (search= +nt +at-mio +install). Although, the solution could any number of things, these documents point out some unique installation steps on NT machines.
Installing Plug and Play Support for ISA-bus Boards on Windows NT 4.0 Systems
AT-GPIB/TNT (PnP) Board Is Not Recognized in Windows NT
Assigning a Driver to an ISA PNP Device under Windows NT
Hopefully these are helpul. Good luck!
-Craig
-scraggs99
(2,703 Views)
