at-mio-64e-3 Analog Output inject DC component
 When I run test panels , when Analog output is wired to analog input(channel 1 to 1), I get DC component together with sine wave.
Voltage is not constant, and when changing AC output ( I hardly understand what  means the scale -10,+10V on the scrollbar, for sine wave generation) the DC part changes proportionaly.
 I have a standard 100pin ribbon cable (unshielded).
But if the DC voltage is not constant it's hard for me to believe it might be the cable cause.
(2,302 Views)
Have you tried shorting ai0 to aignd and reading ai0 in RSE mode?  This should result in a reading of 0 V.  If the voltage is pretty different than the expected, then it could be that your board is in need of calibration.
NI's Calibration Services
(2,289 Views)
