atan2 function
Is there some sort of module that i can insert to implement the atan2
function onto VI? If so where can i find it in the menus ( they are
pretty confusing and unorganized). Thanks
(5,244 Views)
 Phil
I'm not sure what you mean with atan2. There are some triangle functions in LV.
Hope the picture helps you to find it.
Message Edited by Petric on 06-05-2007 01:17 PM
(5,234 Views)
Hi Phil,
you don't say which LabView version you use...
Upto LV7.1 you will find this in the numerics palette, subpalette Trigonometric.
From LV8 on you find this under mathematics -> elementary -> trigonometric.
Easy to find once you know the scheme Smiley Happy
(5,229 Views)
