audio input
hi
everyone,
I need to know the process , how i can take two different signal using sound port(stereo input) & acquiring sound VI in LV8.2. actually to acquire sound is not a problem but i need to take two different signal in right & left channel simulteniously & separately . kindly if someone have some idea kindly post
(5,120 Views)
The sound functions (express and low level) will return both channels if you configure the acquisition for two channels. You just have to separate the data returned with either the split signal function (express function) or index array (low level functions).
(5,109 Views)
Have you done any coding? Post some code so we can understand your problem. My guess is that you are having problem with the "dynamic data" type.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(5,093 Views)
this is the program, i am trying  avoid the express VIs . check the program it is not seperating at all
(5,045 Views)
Try this version. Your code had some questionable things in it. I can't test it since I don't have any way to provide two separate inputs.
(5,041 Views)
You have to do this the proper way. Please go help in the toolbar. Then select Find Examples and search for sound and locate the "Continuous Sound Input.vi". Use this as a base for your programming, and use "save as" then saving ;). Also remember to use Find Example every time you are stuck.
Good Luck 🙂
(5,028 Views)
thanx frnds, i am trying.
(5,012 Views)
