authenticate user.vi
I don't anderstand why the Vi authenticateuser.vi is in Examples in Labview. Indeed, If this VI is locked it is not useful to put it inside exmaples? We can't edit it to create users and login.
Is there a possibiliy to save users and logins to use this VI ? thank you
labview 7.0
Message 1 of 10
(6,158 Views)
Where is this VI?
I couldn't find as an example.
Is it inside one of the examples?
If so, then the example is about how to use it and not about how it works.
VIs are usually locked when they contain LV features which NI does not want the general public to access.
___________________
Try to take over the world!
Message 2 of 10
(6,144 Views)
Excuse me.. it's in dialog examples.
I agree you that some VI could be locked but if this VI is in examples it should be useable?
this VI has 2 inputs: login and password, output are: verified and canceled. But I did not succeeded in changing login (when you save, default login and password appear again when you open another time)
labview 7.0
Message 3 of 10
(6,138 Views)
i can´t find it in LABView too.
but i think you mean the example discussed in the forum:
http://forums.ni.com/attachments/ni/170/83882/1/Login.llb
Message 4 of 10
(6,136 Views)
Yes it is this one.
labview 7.0
Message 5 of 10
(6,130 Views)
If the example at http://forums.ni.com/attachments/ni/170/83882/1/Login.llb is the one you are refering to what part is password protected? I downloaded it and it opens (all three vi's) just fine. If it is another example, please excuse me
Using LabVIEW 7.1.1/WindowsXP Pro SP2
Putnam Monroe
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 6 of 10
(6,119 Views)
I did a search for login from the examples screen and found the login vi. The authenticate user.vi is a subvi in login. It is not password protected and I was able to change the first entry in the table and save it. After changing the table entries, you must right click on the table and select Data Operations - Make Current Value Default, then save the vi. When you open it again, the changes should be there. Here is the vi:
- tbob
Inventor of the WORM Global
Message 7 of 10
(6,107 Views)
Could you save it in L7.0 please? I can modify the array contents but I can't make it as default value (No data operation)
Message Edited by ramiral on 06-29-2005 04:38 AM
labview 7.0
Message 8 of 10
(6,034 Views)
Here it is in 7.0
- tbob
Message 9 of 10
(6,010 Views)
Thank you very much Smiley Happy
labview 7.0
Message 10 of 10
(5,983 Views)
