auto deploy and run a vi on crio?
I have a crio9035. Every time I use it, I need to manually deploy it on labview and run RT MAIN manually. Is there a way to automate these two steps?
Thanks!
(2,268 Views)
Using the project window build your application, deploy and set to run at startup on the RT operating system.
Create a build and use the right click menu to deploy with the appropriate option.
CLA - Kudos is how we show our appreciation for comments that helped us!
(2,247 Views)
