auto frequency increase of simulate signal vi
Hi everyone. I am pretty new to labview. I want to increase the frequency to a simulate signal vi using array of numbers. the for loop should step through the array and output a frequency that will serve as input to the simulate signal vi every 5s changing the frequency from 10hz to 20hz, to 30hz and so forth until bout 1khz.
attached is a vi i have written but something seem not to be accurate
(3,541 Views)
Accepted by topic author marco73
Hi marco,
in general this question boils down to: THINK DATAFLOW!
What's the purpose of that inner FOR loop?
Why not use just one loop at all?
Maybe like this:
(3,532 Views)
@GerdW,
Thanks so much for the quick response. the loop works fine.
I am only trying to figure out how to include the conditional button to the stop, i mean the red dot that is wired to the stop. in the for loop, it goes away leaving broken wires.
(3,503 Views)
Hello marco73
The red dot is the conditional terminal.
You need to enable it for your for loop.
To enable the conditional terminal, right click on the for loop and select "Conditional Terminal"
Derick Mathew
(3,481 Views)
Hi Marco,
the FOR loop and its abilities is explained in the LabVIEW help (continue to read at "create a for loop"!). Did you care to read the help?
(3,471 Views)
Thanks for all your contributions
(3,424 Views)
