auto reset table
hello..
i want to put 10 values to a table and then i need a way to auto reset table
to take new data.how can i do that?
thanks a lot...
(3,788 Views)
Hi Thessaloniki,
either write an empty array to the table or make the empty table default and reset to default using property nodes...
(3,773 Views)
thanks for interesting!!
could you be more helpful?
i mean... how can i use property  node,in this VI?
thanks again!
(3,765 Views)
Here's more information about property nodes on NI's site.
The short answer is that you right-click on the indicator, select Create_Property Node, select value and place the node on the Block Diagram.  Once it's there you can right-click it and make it to writeable and create an empty array constant on the input terminal.  This replaces the existing data with the 'nothing' contained in the empty array.
Message Edited by jcarmody on 03-15-2009 07:27 PM
Jim
(3,751 Views)
thessaloniki,
jmcbee just outlined how to do this in this thread.
ColeR
Field Engineer
(3,722 Views)
