auto scale polar graphs
Hi All,
I've got a beautifull excell sheet with 2 columns. One column with degree values and one column with dBm values. I've got my program to make a polar graph, but i still have to manually set the max and min dBm values. I've attached a simplefied program which will function without the spectrum analyser and other stuf, but which will illustrate my problem.
To anyone who is willing to help me:
I thank you in advance
Greetings from Holland,
Emile Knottnerus
edit: added attachement
Message Edited by milo_unlimited on 10-10-2008 03:09 AM
(3,293 Views)
Hi Emile,
you forgot the attachment.
Mike
(3,289 Views)
Accepted by topic author milo_unlimited
Hi Emile,
you can use the bundle by name function to set the min and max value.
Hope it helps.
Mike
(3,285 Views)
Works like a charm 🙂
thnx Mike
(3,252 Views)
