auto width in excel
hello,
i have created this excel file.
i was wondering if someone can how me how to autosize the width.
i want it to autosize the width as i open up microsoft excel.
can someone show me how to do that.
thanks
Message Edited by krispiekream on 06-16-2008 07:55 PM
Krispiekream
Message 1 of 16
(8,016 Views)
Hi krispiekream,
You can use the autofit method or you can write a macro in excel.
Have a look at this thread http://forums.ni.com/ni/board/message?board.id=170&message.id=24472&query.id=67391#M24472 There is an example which includes a "columns" property and a "autofit" method.
Charly
It's always sunny in California! Certified LabVIEW Associate Developer!
Message 2 of 16
(7,998 Views)
great,
thanks for your help.
that worked.
but one last question,
how do i make it fit into one page?
so its easier to print.
Krispiekream
Message 3 of 16
(7,976 Views)
Hi krispiekr…,
if you want a fix width, then you can set the column width "manually" (column by column with ActiveX functions).
Mike
Message 4 of 16
(7,974 Views)
i got it to autofit and it worked fine.
right now, i either want to close it save it.
i am having a hard time saving it with autosize width already.
everytime it popped "save yes", "no","cancle".
when i put save. and oonce i open it up again, the file did not autosize the width for me because it save has delimiter or something.
Message Edited by krispiekream on 06-17-2008 11:58 AM
Krispiekream
Message 5 of 16
(7,970 Views)
i want it to automatically print using this
Message Edited by krispiekream on 06-17-2008 12:31 PM
Krispiekream
Message 6 of 16
(7,956 Views)
i did this.
yet it still print out 2 pages.Smiley Sad
Message Edited by krispiekream on 06-17-2008 01:11 PM
Krispiekream
Message 7 of 16
(7,947 Views)
Hi krispiekr…,
could it be that your event execute two times?
Mike
Message 8 of 16
(7,939 Views)
Mike
it could have, but i have tried it so many other ways.
i think i will give up on this.
Krispiekream
Message 9 of 16
(7,906 Views)
Hi krispiekr…,
maybe it helps if you change the mechanical action of your button to "latch when released". If it don´t helps, can you upload your code?
Mike
Message 10 of 16
(7,880 Views)
