autocode compatible VIs
Accepted by topic author PhilipJoeP
Yes I think things are clear. It was the terms that were confusing. Effectively, changing the target, changes the development system and different development systems have different capabilities. I don't think it's a matter of a function not generating the correct C code. It's more a matter of some functions not generating any C code because they are not supported on a certain platform. For example, you can use an ActiveX function with a normal windows target but those functions on not supported on a micro target.
edit- anyways, yes, if you are going to target a micro, your top level VI should not be under My Computer since that will assume you are developing that VI for windows.
Message Edited by Dennis Knutson on 07-01-2009 10:36 AM
Message 11 of 12
(802 Views)
Yup... that makes makes sense.  Thanks for clearing up the terminology.
Message 12 of 12
(796 Views)
